BBQninja
Apr 21, 2021Aspirant
Nighthawk EX8000 extender and Ipad connectivity
Having issues with my old Ipad browsing experience when I connect to the Nighthawk EX8000's extended wifi. I can connect fine but when I try to use the Safari browser, the internet connection spins/f...
Apr 21, 2021Guru - Experienced User
what primary router do you use?
Does it work fine with a different browser on the ipad?
Do apps on the ipad have issues or only the browser?
BBQninja
I use the Verizon Fios Quantum Gateway router. It is my only router.
I have not tried a different browser on the ipad. I'm not sure you can install any non-Apple browser on the ipad actually.
No other issues other than the browser and when connected via the Netgear wifi extender. When I connect the browser to my primary Fios router's wifi, it works fine. Only when I connect to the Netgear's 2G or 5G extended wifi band does it not work.
- plemansApr 21, 2021Guru - Experienced User
What quantum gateway is it?
- BBQninjaApr 21, 2021Aspirant
G1100 AC 1750
purchased in 2015
try reading a few of the verizon posts on it.
Solved: Connecting FiOS Router to Netgear WN3000RP Range Extender - Verizon Fios Community
