Bonfire87's avatar
Bonfire87
No Model or Serial Number on Extgender
I received an email to update firmware.  I have a wifi extender that is 2 1/2 yrs old.  There is no model number or serial number anywhere to be found on it.  How can I figure that out so I can ident...
  • jvasanth1984's avatar
    Mar 31, 2018
    Hi Bonfire87,
                            As per your description, it could be EX6200 or EX7000. You can login to it using mywifiext.net after connecting any device to it. Model of extender can be located once you login to the interface of the unit. You may perform firmware upgrade from the interface too.
