polly83
Feb 12, 2026Aspirant
Problems using AX1600 with AX1800
Hello All, I recently bought an AX1600 (EAX12) extender to help with the range of my wifi. My setup is : CICSO 897MA to a Netgear AX1800. This has worked without issues since the Netgear AP was ...
CrimpOn
Feb 12, 2026Guru - Experienced User
There are a lot of devices with the marketing label "AX1800"
It would help to know which product the new EAX12 is connecting to.
Is the SSID being broadcast by the existing access point the same as the SSID from the Cisco?
- polly83Feb 14, 2026Aspirant
Hi,
Thanks for the reply. The AP is a WAX610 which serves the SSID. The CISCO is a router and has no wifi capability, just 8 internal ethernet ports. The CICSO is the connection to the fibre broadband and has worked perfectly for 8 years or so from when it was iinstalled. It does serve the DHCP.
