Childs's avatar
Childs
Follower
Apr 07, 2026
Range Extenders
I am an inexperienced user of technology. I purchased 2 range extenders at different time, therefore they are not the same model. Can I use them both? My router is in my husband's office on the lower...
  • CrimpOn's avatar
    Apr 07, 2026
    Yes, any number of WiFi extenders can be connected to a WiFi router.  Typically, the extender should be close enough to the router to get a good signal and also close enough to the device being connected to provide a good signal.  Often "half way" is a good compromise, depending on the building construction.
    An important consideration is how the target device expects to connect.
    • If the goal is to provide an Ethernet connection, then obviously the WiFi extender needs to be in the same room as the device.
    • If the goal is to "extend" the WiFi coverage, then I would start with about "half way" and see how it goes.
    People often have a choice of having the WiFi extender broadcast the same WiFi credentials as the primary router or defining a different WiFi network name.  This is often useful in preventing the target device from attempting to connect to the primary router rather than the extender.
