DLW3599
May 11, 2026Aspirant
Satellite for rs100
I need to expand an RS100 for better coverage. Is there a satellite compatible with it,or I would I achieve this? thanks for any response
- May 11, 2026
Review this?
https://www.netgear.com/home/wifi/range-extenders/exs27/
How big is the home in sq feet?
May 12, 2026Guru - Experienced User
Size of the home will make a big difference.
Extenders by their very nature, decrease the speed of devices connected to them and increase latency.
So sometimes, its better to centrally locate a router before moving to adding an extender.
Plus what are you using it for? If its just to connect a few devices and not gaming/streaming, a different extender would work.
But if you're gaming, streaming, or its a work critical device, we'd probably recommend a higher performing model than otherwise.
So details help
