mlefmann
Jul 19, 2019Follower
softtree scam
I just spent 45 minutes with a "tech" person trying to set up my extender as I have a new U-verse network. This person was IN my computer. I followed a netgear.com link. He goes through all these com...
Christian_R
Jul 22, 2019NETGEAR Employee Retired
Hello mlefmann and DianeB13,
Thank you both for posting. We can confirm that Soft Tree is not an authorized NETGEAR support channel. I would like to work with the both of you directly on any issue(s) you maybe encountering with your device. When you get a chance, feel free to send me a message regarding the issue(s) you're experiencing.
Furthermore, to ensure you are getting in contact with our Support Team, please use the link below. You will have the option to register your device(s) and open a support ticket.
https://www.netgear.com/support/default.aspx
Respectfully,
Christian
LisaAkin
Jan 29, 2020Aspirant
I think I may have just been a victim of the Soft Tree scam....I tried to set up the extender and it wouldn't work...I followed the links and someone did get it set up and put the Genie software on my computer. I paid for it. Please let me know if I have made a huge mistake and if our network is comprimised.
- Alse12Mar 25, 2020AspirantMe too.
I granted them remote access.
They connect through the website leaflet that comes with the Netgear bought from amazon.
I didn’t pay anything but worried they have installed a spyware.
How do I find out?- MoniQ06Jan 28, 2021Guide
I found after all said and done and I saw the charge and I did my research. I didn't buy from
Amazon, I bought directly from Best Buy in town. There should be a class action lawsuit in my opinion because of the fraudulent mess with Netgear.- schumakuJan 28, 2021Guru - Experienced User
MoniQ06 wrote:There should be a class action lawsuit in my opinion because of the fraudulent mess with Netgear.
It does not matter from where you buy. This scam and fraud scheme exists for many vendors and are driven by the same Mafia-style oganisations.
And again for the records: Netgear isn't involved. Much more, they try the best that related fraudulent paid search results will be removed.
