GForceRTX2090Ti
May 07, 2020Tutor
WiFi extender keeps dropping connection, and it's driving me insane.
Seriously, this thing just decides to drop everything at the most random times and lose all connection. I've tried every possible solution to try and fix this but nothing's worked. My firmware is up ...
May 07, 2020Guru - Experienced User
What router are you connecting to?
Firmware on the extender?
Have you tried it in AP mode directly connect to the router with a 6ft cable?
GForceRTX2090Ti
May 07, 2020Tutor
I'm connecting to a comcast router.
Firmware is V1.0.1.86.
I have tried the extender directly connected to the router and even after it started up it still didn't recognize that it was an ethernet connection and it didn't work properly.
- plemansMay 07, 2020Guru - Experienced User
GForceRTX2090Ti wrote:I'm connecting to a comcast router.
did you have the switch in Access point mode when you did it this route?
And it didn't work directly connected but it did through powerline?
I'm curious how its working in access point mode through powerline when it didn't directly connected?
