Pianoeliz
Sep 24, 2020Tutor
WIFI extender
Our range extender works well after it is set up, but after a period of several hours, when we try to connect on both bands, 2.4. And 5G, we get the message "no internet connection." When we unplug...
Sep 25, 2020Guru - Experienced User
Did you install using the wps method?
Or using the installation wizard?
Have you given the extender a static ip address in the ubee?
Pianoeliz
Sep 25, 2020Tutor
The WPS button on the router did't work, so I used the wizard.
No I haven't set a static IP address, and don't know how to. Maybe that is the problem?
