Krille2
Oct 26, 2017Follower
WN2500RP Range Extender KRACK exploits.
What about the older WN2500RP Range Extender? As an extender it is obviously affected by the WPA KRACK exploits. Netgears security advisor only list new products. Netgear really need to publish a...
V8011
Nov 04, 2017Initiate
Bumping this thread to simplify my previous post
Netgear, on your Security Advisory page for WPA-2 Vulnerabilities your WN2500RP Extender is not listed.
1) Are you still supporting the WN2500RP V1?
2) Will there be a firmware update to patch the Krack vulnerability and additional security issues?
Would appreciate a reply from anyone regarding the questions above. Sincerely - V8011
ElaineM
Nov 08, 2017NETGEAR Employee Retired
NETGEAR provides security updates to fix vulnerabilities or upgrade security in products for the longer of four years after product release date or two years after product end of life.
It appears your product is outside of those dates.
- rjm676Nov 09, 2017GuideThe firmware for WN2500RPv2 (1.0.1.46) was updated on 11/06/2017. Can that be used for WN2500RPv1?
