joedelaneycalp
May 04, 2020Aspirant
WN3000rpV.3
trying to connect this extender to fritzbox router. have reset it many times but router is not showing the extender. Any ideas?
May 04, 2020Guru - Experienced User
Try running the install assistant and not wps. Not all device makers code wps the same.
joedelaneycalp
May 05, 2020Aspirant
Dont have an install assistant link? If you have one, please send it on.
I already have a netgear extender working but when i try to add a new extender, I keep getting asked to register as a new user. I already have the product listed on netgear site under my account. Not sure why I need to re register when I already have. Very frustrating trying to solve this.
- plemansMay 05, 2020Guru - Experienced User
shut off the running one when you setup the new one.
the support site has a video walk through. its the 2nd video on the site
- joedelaneycalpMay 06, 2020AspirantExtender is showing up when I log into router but not showing up as a network to connect to?
- plemansMay 06, 2020Guru - Experienced User
Is the old one showing up under the access control or the new one?
And did you set a seperate ssid?
