joedelaneycalp
May 04, 2020Aspirant
WN3000rpV.3
trying to connect this extender to fritzbox router. have reset it many times but router is not showing the extender. Any ideas?
May 05, 2020Guru - Experienced User
shut off the running one when you setup the new one.
the support site has a video walk through. its the 2nd video on the site
joedelaneycalp
May 06, 2020Aspirant
Extender is showing up when I log into router but not showing up as a network to connect to?
- plemansMay 06, 2020Guru - Experienced User
Is the old one showing up under the access control or the new one?
And did you set a seperate ssid?
- joedelaneycalpMay 07, 2020Aspirant
Both are showing up.
No I did not set up a separate SSID. How do I do that?
Tks
- plemansMay 07, 2020Guru - Experienced User
You can log into the extender
mywifiext . net
and change the ssid.
Sorry - change it to what exactly?
Not really sure what to change it to?
Thanks,
Its your wireless name. change it to whatever you'd like.
i have changed SSID but extender is not connected to router. When I log in to fritzbox router, I can see connected and not connected devices. The new named extender is in the not connected section. Making progress and thank for help.
did you hardwire into the extend you want to setup (with the working one powered off) and run setup through the installation assistant? And then during setup, just use the different ssid you wanted?
no - i was trying to connect by wifi.
I've connected router/extender but now get this error message;
The Extender cant connect to the Router
and yes I'm using the new SSID I created
- joedelaneycalpMay 08, 2020Aspirant
Now on my 4th day trying to get this extender to work via hardwire, reset, wps, changing SSID.
At different times after a reset or hardwire, the extender shows up as connected on the router but won't connect to wifi
At other times, wifi is connected but doesn't show up on router as being connected.
I appreciate any advice that I may have missed....Don't ever remember it being this hard to connect the other Netgear extender I have also set up.
- plemansMay 08, 2020Guru - Experienced UserIf its a new purchase, you can contact netgear and use the free 90 days of support from date of purchase.
Its not a new purchase - its about 5 years old as is the other extender I have in the house which is working fine.
Any advice as to how to fix? Surely not the 1st person in the world ot have this issue?
No one said you're the first person to have this issue.
but if you've done the following:
Tried setup hardwired in
tried after a factory reset
tried after re-installing firmware (in case its corrupted, a reset only removes settings)
Tried setup when the other extender was off
then you're running low on options.
I'll try firmware upgrade...after that, I think you're correct, it may be past its sell-by-date
Not sure how I can do it if I can't connect it to wifi as I don't have ethernet connection on my laptop? Any help or suggestions appreciated.
you can manually download the firmware to a pc/laptop.
then hardwire into the device and you can manually install the firmware.
the manual walks you through it.
to get the firmware and manual go to
netgear.com/support/ and type in your model.
