Bob5545's avatar
Bob5545
Recent firmware Update messed up my Extender
  • Hardware Version: EX7000
  • Firmware Version: V1.0.1.78_1.0.140
This update has caused issues with my extender.  Before this update never had any problems.  Now getting devices disconnected, searching for ip address, intermittent operation.  Continually have to restart the extender to get stable operation.
This is really annoying.  When a vendor updates firmware it should be checked, re-checked.  I was considering using Netgear Routers for one of my consulting projects, but stuff like this makes me wonder about their abilities to manage their products.
And when I tried to contact them to advise them, I have no options for support, even when it is their issue.  My time for their support has expired!
Netgear either fix your fimrware, or give customers the option to roll back their devices to firmware that works with issues.
  • I have download the previous version of firmware.
    The new version is causing all kinds of issues with the extender.
    Will installing the previous version cause me any issues????
    Thanks
    • Dyros's avatar
      Dyros
      Messed up mine as well months back. My security cams kept getting dropped along with my laptop sitting practically right next to the 7000. Reverted to firmware V1.0.0.66_1.0.126 which you can download from Netgear. Months ago I did this, not a single problem since.
      • Bob5545's avatar
        Bob5545
        1.0.1.78_1.0.140
        Has this version of corrupt firmware been fixed.
        It does not work!
  • Is there a newer firmware update than the update referred to in this post.
    • Dyros's avatar
      Dyros
      Welp, still using V1.0.0.66_1.0.126 and...months later, no problems...not one. Security cams work perfect. I still won't update. Don't fix what's not broken right?
