katiekate
Feb 06, 2015Novice
Recomendations for RV Park
Looking for a product recommendation to use in a campground with WiFi. It was suggested to get a wifi range extender. Thanks in advance for your help. I did do search, but nothing came up. Kathy
fordem
Feb 07, 2015Mentor
Where is the laptop - inside an RV surrounded by sheet metal?
My suggestion would be more along the lines of a USB wireless adapter, possibly on a USB extension cable so that it could be positioned for optimum reception quality.
Range extenders have their own issues and will have to be reconfigured every time you move from park-to-park, and it's not as simple as adding a new "hot spot" on the laptop. If you don't move about much, it might work.
