skibum75
Sep 25, 2019Aspirant
Recommendation request, Netgear Access Point for Orbi RBR50
My use case: I have very good cable internet feeding my equally good Orbi Mesh network (1 hub 1 satellite). I want to provide a WiFi signal to my sister's house, two houses away (200'). The neighbor ...
- Sep 25, 2019
200ft is pushing the distance at which wireless works well. I think you'd end up with issues. A point to point system might be a better option for you. I'll post a couple links off amazon. I'm not recommending them as I've never used them but I think you'd have better results going like this:
orbit router---point to point system---Acess point at sisters house.https://www.amazon.com/dp/B007ZDC64I/ref=psdc_1194486_t2_B002K683V0
https://www.amazon.com/EZ-Bridge-Lite-EZBR-0214-Outdoor-Wireless-System/dp/B002K683V0
There's many different types of these systems so I'd do your research first.
I know I've tested my outdoor orbi at around 150ft (outdoor, direct line of sight) and barely pulled 10mbps. thats why I think you'd be stretching it at the 200ft.
Sep 25, 2019Guru - Experienced User
- skibum75Sep 28, 2019Aspirant
Thanks for the tips. Was hoping to avoid running power to the mast but will add this to my options.
