benrinnes
Aug 14, 2018Aspirant
Recommended range extender for a second office 50m away
Hi folks,
I work for a nonprofit organisation who have just taken on the lease for a new office which is located approximately 50m away in another office unit.
To help save costs of havi...
- Aug 14, 2018
I don't think Netgear makes anything suitable for this.
A Point-to-Point bridge is probably a better match for what you want. Ubiquiti makes a lot of these:
https://www.ubnt.com/airmax/nanostation-ac/
https://www.ubnt.com/airmax/nanobeam-ac-gen2/
You need a pair of these - one at each site. Ideally they'd be mounted outside (and over any traffic). You need to align the antennas, since they are directional. Note I don't use these, so this isn't a recommendation - just a suggestion of something that looks suitable.
A pair of the first two (NS-5ACL-US) would run about $100, a pair of the second (NBE-5AC-Gen2-US) would be about $180. I'd probably go with the more expensive ones.
These just bridge between the two sites, so you'd also need at least one wireless access point in the new office. If a single AP will do, then you can use any reasonable router in AP mode. An R7000 for example. If the space is too large for a single AP, then get an Orbi (the RBK40 package for example).
Aug 14, 2018Guru - Experienced User
50m is a pretty long span. Would it be practical to run an ethernet cable between the offices?
Is this span outdoors or indoors?
If outdoors, is there a clear line of sight to the other building?
How many people will be in the new office?
- benrinnesAug 14, 2018Aspirant
Thanks for the response.
It wouldn't be possible to run an ethernet cable between the offices. It's located on a shopping arcade with other units, different landlords and council restrictions etc.
The span is outdoors with a clear line of sight.
Approx 4-6 people in the new office. 10 in the current office.
- StephenBAug 14, 2018Guru - Experienced User
That's incredibly helpful, I'll follow up on the products listed as possible options.
Many thanks for all your time on this, it's very much appreciated.
