Chris_980
Jun 27, 2021Aspirant
Red Flashing Power Light
Found the Wi-Fi network on the other half of my house wasn't performing as exptected, check on the externder and it had a red flashing power light and white flashing lights for the notification LEDs....
Chris_980
To note - I also tried and apparently successfully deployed the firmware through tftp but still flashing with no usable extender
- plemansJun 28, 2021Guru - Experienced User
tftp can fail at many points does it successfully flash or what error did you get?
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- Chris_980Jun 28, 2021Aspirant
Windows advises it completes successfully in CMD. Extender just sits there with a red flashing light on the power LED but every other LED is off.
tftp is definately enabled.
Haven't had a go at the NMRP flash, but looking at it I'm not sure I'd know how to. I'll see what I can do with that and will report back.
Thank you
nmrpflash works fairly well. I've used it when tftp didn't work. its a little more difficult.
You might have a hardware failure. It wouldn't be the first time.
