rpunossbc
May 14, 2020Aspirant
red light blinking on device
hello..we bought an extender ex2700 a couple of days ago..everything was perfectly fine until this morning i noticed there is blinking red light on the device..what does that mean?thank you
May 14, 2020Guru - Experienced User
tough to tell because there's more than 1 led on the device and you didn't give us much info.
If you go to netgear.com/support/ type in the model number. It'll take you to the support site with the manual that goes over what each led is and means.
rpunossbc
- plemansMay 14, 2020Guru - Experienced User
it means the connection between the extender and a device connecting to the extender is poor.
- rpunossbcMay 14, 2020Aspirantso meaning theres no problem between the router & the extender right?its just the device connecting to the extender?i put a cctv cam on the garage that my main concern right now..should i change the position of the ext nearer to the cctv?
- rpunossbcMay 14, 2020Aspirantits not solid red though its just blinking for about 25secs then go green then blinks red again
