rj1959
Nov 16, 2021Aspirant
Reinstalling a Nighthawk AC1900 WiFi Range Extender
I moved to a new address and now have new internet service. My range extender was setup under my old wifi network. I now can't connect it to my new network because all of the instructions say to conn...
rj1959
Nov 17, 2021Aspirant
I tried resetting the router and now I have a network named ASUS. I tried logging into it using "admin" and "password" to no avail. Everything I can find on the support site tells me to go to their link which I can't do.
Nov 17, 2021Guru - Experienced User
Asus wouldn't show up unless your primary router is asus and you're using WPS.
It might just be another network showing up.
Have you tried hardwiring a pc/laptop into the extender and using the installation assistant
