mogulman52xx's avatar
mogulman52xx
Replace WP2500RP. EAX80 vs EX7700 or Other
Setup 2 story, 3700sq ft house + backyard. 2 - Netgear WN2500RP extenders (2016) New Frontier Arris NVG468MQ Router located in corner of 2nd story I'm looking to replace both extenders.  I am l...
  • plemans's avatar
    Nov 16, 2021
    If you're needing 2, i'd go with a mesh system and not just extenders. You don't have to replace the arris box.  You can connect an orbi/mk system to it and either put the netgears IP address into the arris's dmz or the netgear in access point mode.
