Pops2024
Jan 31, 2024Follower
Reseting an EX6150v2 wifi extender
Probably a quick and simple question... So when I resync and reconnect my wifi extender to my router, in extender mode, and with same SSID, it disapears off of my list of wifi networks to connect...
Feb 01, 2024Guru - Experienced User
Yes. The EX6150v2 is a mesh extender. That means it uses the same ssid/password as the router and allows devices to switch between it and the router as needed. Thats the purpose of the "mesh".
If you want more details about connections, log into the router and lookup the extender's IP address in the attached devices page. that IP address will let you access it. Or you can use the app. I'm not a huge fan of the app using the extender but you can.
