Dubodj
Feb 13, 2012Novice
Roaming with a WN2000RPT
So here is my situation. My house is basically split in half when it comes to wifi due to concrete and piping. I have a Belkin router but I bought a Netgear WN2000RPT to help bridge the gap. I set it ...
tpcguy
Feb 13, 2012Guide
Hi,
That's possible, just connect a PC to the extender (disable the W/L capability of the PC) then access the mywifiext.net or mywifiext.com, go to W/L settings then change the SSID of your Extender network and apply. There you go!
tpcguy
tpcguy
