Sheamatt
Jun 26, 2020Aspirant
Router Dropping connection
My router is driving me crazy. Internet works great for a day or maybe a few hours then lose connection. The wifi is on and connected but with no internet connection. Hardwire is same. Reboot the rout...
Jun 26, 2020Guru - Experienced User
What modem are you connecting it to?
How long has it been going on?
when it happens, do all devices drop, just wireless, or what exactly happens?
- SheamattJun 26, 2020AspirantDirectly connecting to Verizon fios coming into house. Like a month or so. This morning woke up and no connection. Rebooted perfectly fine. Everything goes down. Wifi is connected but no internet. Direct connection no internet either.
- plemansJun 26, 2020Guru - Experienced User
Fios still needs a gateway.
https://kb.netgear.com/23977/Will-my-NETGEAR-router-work-with-Verizon-FiOS
- SheamattJun 26, 2020AspirantWow. Will try later. I guess bc it worked without it, I figured no issue but I will try this setup. Thanks
