VT1959
Jul 25, 2021Initiate
Router Link LED doesn’t light up any longer, so I have no WiFi connection. Please advise.
I already tried doing the factory reset on this extender and still the Router Link LED doesn't light up. I had been using this extender for over six months and had no problem. My iPhone and iPad was ...
Jul 25, 2021Guru - Experienced User
1. what router do you have?
2. what firmware is on the extender?
3. are you able to hardwire into the extender and navigate its gui?
4. what are all the led's on it goind? not just router link. color/blinking/solid
5. what method of setup are you using? (wps?)
- VT1959Jul 27, 2021InitiateThank you for replying to me Plemans (Guru):
1) My router is from the cellphone company CLARO in Puerto Rico.
2) The extender is NETGEAR.
3) I don’t know how to hardwire, neither know what is GUI.
4) The CLIENT LINK & POWER are solid green. Since now I have the extender unplugged I don’t remember but I think the WPS was also solid green.
5) I had set it up from the NIGHTHAWK APP.
Sorry, I’m not too good with this technology.- plemansJul 27, 2021Guru - Experienced User
1) My router is from the cellphone company CLARO in Puerto Rico.----what model is it? thats key
2) The extender is NETGEAR.----aware of this. but model and firmware version are key.
3) I don’t know how to hardwire, neither know what is GUI.----hardwiring is connect an ethernet cable to the extender and directly wiring a pc/laptop to it. Then you can us the IP address for the extender to log into and make changes.
