Dianagg4
Jan 21, 2020Follower
Router link light not lighting up
Both power light and wps light is on green but the router link light does not turn on any color
Jan 22, 2020Guru - Experienced User
Thatt usually mean its not linked to the router.
Is it setup? Can you see the ssid broadcasting?
have you tried logging into it to see if its linked with the router?
have you tried re-running the setup process? if wps method doesn't work, try the smart installation wizard.
here's where you get the guide, manual, install videos, etc.
