gil44
Dec 16, 2018Aspirant
router or extender
Hi, I am a novice and bought a Nighthawk X10 AD7000 smart wifi router model R8900. I have Spectrum cable for my internet and wifi in the home. Bought Ring Video doorbell and camera and need to get ...
Dec 17, 2018Guru - Experienced User
Are you also using the router/gateway that Spectrum supplied? If so, what model is it?
gil44
Dec 17, 2018Aspirant
Yes, Spectrum model TC87150
- StephenBDec 17, 2018Guru - Experienced User
I'm thinking it's a TC8715D?
You purchased a high-end router. It has more capacity than your Spectrum. It could have some more range in the 5 Ghz band, but I don't think it will help much with the Ring doorbell, etc.
You could of course try the R8900 and see. But I think a better plan would be to exchange for for a product that can expand your range.
One option is to get a WiFi extender (for example the EX7500). You'd put that somewhere between your router and your outdoor devices, and it would relay the traffic from them to your router.
A second option is to get an Orbi wifi system, and deploy it as an "access point" - using it for wifi instead of your Spectrum router. There are several models that could work - if you are interested in exploring that, please give us some more information on the size of your home (square feet of coverage area, number of floors, and whether you have indoor dead spots in addition to issues reaching outside).
