robertomurcia
Jan 25, 2021Aspirant
Router password doesn't work
When I enter the router password, as I usually do without the extender, it tells me that it is wrong, despite being the correct one. WIFI range extender EX3110.
Jan 26, 2021Guru - Experienced User
Not sure whats going on here on your description..
Are you saying when you try to connect to the extender, it says wrong password?
Or when you connect to the router?
What router is it?
What method of install did you use? (wps or the installation assistant)
mjones3141
Jan 26, 2021Aspirant
I have the same issue - the wifi password is accepted but intermittently rejected.
My process was:
1) setup ex7700 extendter with account and wifi password the same as router wifi
2) device (ipad) internet connection works next to extender using wifi password
3) walk to office next to router, connection works
4) return to room with extender later in the day, connection does not work and I receive device notification saying wifi password is incorrect
5) power cycle extender
6) wifi password is accepted
If this doesn't stop I will return the router immediately
