robertomurcia
Jan 25, 2021Aspirant
Router password doesn't work
When I enter the router password, as I usually do without the extender, it tells me that it is wrong, despite being the correct one. WIFI range extender EX3110.
Jan 26, 2021Guru - Experienced User
Not sure whats going on here on your description..
Are you saying when you try to connect to the extender, it says wrong password?
Or when you connect to the router?
What router is it?
What method of install did you use? (wps or the installation assistant)
robertomurcia
Jan 26, 2021Aspirant
when I try to connect to the extender, it says wrong password. When I use the router I can connect I used wps to install The router is Claro SSID inalambric net
- plemansJan 26, 2021Guru - Experienced User
Try factory resetting the extender and reinstalling using the installation assistant and NOT wps
