robertomurcia
Jan 25, 2021Aspirant
Router password doesn't work
When I enter the router password, as I usually do without the extender, it tells me that it is wrong, despite being the correct one. WIFI range extender EX3110.
robertomurcia
Jan 26, 2021Aspirant
when I try to connect to the extender, it says wrong password. When I use the router I can connect I used wps to install The router is Claro SSID inalambric net
Jan 26, 2021Guru - Experienced User
Try factory resetting the extender and reinstalling using the installation assistant and NOT wps
