jennynilsson
Jul 25, 2019Aspirant
router SSID name too long for N300 extender?
Hi, I just noticed that the router SSID was truncated by the extender while creating the name for the extended network. Does the extender have a character limit for the incoming router network name...
- Jul 25, 2019
thanks for the suggestion, yes I think that would be the best way do solve it. But how do I access the extender Web UI if I can't access the network? that's more or less where I got stuck ;D
Or should I connect it with a ethercable in the meanwhile til I get the SSID problem solved?
thanks again!
jenny
schumaku
Jul 25, 2019Guru - Experienced User
The SSID (network name) can be up to 32 chars long, the security key 8...63 chars when I have it right - the WN3000RPv3 should allow this, too.
Ensiure your extender has the current firmware in place - WN3000RPv3 – N300 WiFi Range Extender - Downloads. Let us know how and where you think the SSID is truncated (number of chars?). Screenshots might help, too.
