Kantor
Oct 02, 2020Follower
Router Suggestion
Greetings, I currently own a standard DSL Smart/RG SR505N. This came with my DSL from TekSavvy. My current speed is 50Meg download 10Megs upload. I love the mesh routers but it seems that the...
Oct 03, 2020Guru - Experienced User
You can use a mesh system but put the mesh system in access point mode.
The orbi devices support access point mode.
Then you just disable the wireless on the ISP supplied device to keep it from causing wireless interference.
