Majec
May 11, 2020Aspirant
Router to extender ex6100 connection issues
Router not recogonizing extender? try to type same password into the EXT_ and doent connect Do I need to check WPA-PSK [TKIP] + WPA2-PSK [AES] on wireless so router sees extender?
May 12, 2020Guru - Experienced User
Router not recognizing extender or extender not recognizing router?
Did you set it up with wps or the installation wizard?
Try the wizard if you used wps. factory reset the extender and run the installation wizard.
What firmware is on the R6900P?
Firmware on the EX6100?
- MajecMay 19, 2020Aspirant
Once I upgraded the firmware on my AC1900 Router the extender worked on the WPS button the extender genie or the mywifiext
or the IP address: 192.168.1.250 would not activeate not sure why is there a setting I am missing on the AXC1900 routere?
- plemansMay 19, 2020Guru - Experienced User
I'm not sure what to even make of what you wrote. You first put that wps work and then wrote about not activating.
Maybe a better description of exactly what you're doing, what happens would be more beneficial
- MajecMay 20, 2020Aspirant
Sorry about that, so the extender is working only set-up throiugh the wps button on the extendeer and router. however, trying to get into the extender throught either the netgear genie or the ip address 192.168.1.250 is impossible.
Is there a setting within the AC1900 router that would allow me to get into the extender netgear genie to see if there is a firmware to update on the exender?
