LukeUK_
Jan 15, 2022Aspirant
routerlogin.net not trusted on Apple: EX6410 — AC1900 WiFi Mesh Extender:
Dear community, Please help me set up this wifi extender for Apple devices (iPhone, iPad). I have been trying for two weeks with zero success. Good news: The wifi extender is successfully i...
Jan 15, 2022Guru - Experienced User
routerlogin . net would be to connect to the router, not the extender.
the extenders would be mywifiext . net or its ip address from the router.
Did youo setup the extender using wps or using the installation assistant?
LukeUK_
I have tried both installations.
- plemansJan 15, 2022Guru - Experienced User
If you search the vigin forums, you're not the first to have issues connecting an extender to their hub 3.
- nielsvdsJan 15, 2022Luminary
routerlogin.net is an internal website to configure your Netgear device and is unencrypted (http) which means the username and password you enter can be recovered when using packet sniffing.That is why you get that warning when you try to reach it in your webbrowser. Try what is said in this video: https://www.youtube.com/watch?v=fPSPBOSCHps
It will be similar for NETGEAR.
Try to disable use private address: https://support.apple.com/en-us/HT211227 . That sometimes can give issues.
