Sanix
Apr 15, 2012Follower
Routing does not work
Hi, I'm using the product WNDR37AV and have two questions: My modem is connected to an vpn router. I connected that one to the wireless router. The internet works fine for all clients connected to...
jmizoguchi
Apr 15, 2012Virtuoso
if you have router and wanted to be on same network then you need to setup wndr as AP
http://kb.netgear.com/app/answers/detail/a_id/965
this well discussed. will NOT change
use extender such as wn2500rpt , wn2000rpt to connect to wndr3700 if you want to extender wireless safely.
Why do I have to use no security, if I want to use another access point as repeater. This basically renders this product useless, if you want to use repeating. WEP cannot really be called a secure solution. Is there at least a possiblity that I can limit the access the certain MAC addresses?
