KelKaiHina
Mar 29, 2020Aspirant
rR6900/ not connecting to internet
My router will not connect to the internet, as well there is only the first 2 lights that are blinking, the rest are not... I have rebooted a few times & I keep getting the same thing.
KelKaiHina
Mar 30, 2020Aspirant
What do you mean by firmware? Or like how do I look it up to find it?
It is not new. I apparently purchased it in January of 2017.
When I did press & hold down for 7-30 seconds it just kept the 2 first lights on. Nothing happened. If that makes sense ?
I’ve also unplugged both router & modem power & waited at least 15 seconds & when I plugged both back in my modem went back on but the router still only has the first two lights on. The second button keeps blinking.
Mar 30, 2020Guru - Experienced User
What modem are you connected to?
the first 2 lights are power and internet.
Did you try going through setup after resetting?
