lehenryjr
Dec 05, 2014Novice
Says its connected; but no Internet service
I just received my Netgear WN1000RP. The use of the item is supposed to be very simple. Unfortunately, it's not working correctly. I plugged it up, waited for it to be ready, pressed the WPS but...
hjmcgrath
Dec 14, 2014Novice
I have solved my problem. After configuring the extender I unplugged it from the wall and shut off the router. After turning the router back on and letting it get completely up and on the internet I plugged the extender back in. When the extender comes up it works perfectly with internet access. When I moved it to another location it again couldn't get on the internet. Repeating the unplugging, shutting down the router and repeating the process of powering the router back up and re-plugging the extender in and amazing it works again. Weird behavior but it works.:)
