eyal27ny
Apr 11, 2018Follower
Seamless Roaming between access points
Hello. I have two AC1900 EX6400 set as Access points between second floor and a basement (Wired connected via Moca 2.0) I don't think I get Zero roaming as the connection to the access point stays ...
- Apr 13, 2018
Hello eyal27ny
The EX6400 does not have the option to hand off the devices to the strongest wifi signal it will only do this when the device has completely dropped the signal from the extender.
DarrenM
DarrenM
Apr 13, 2018Sr. NETGEAR Moderator
Hello eyal27ny
DarrenM
