sjuannavarro
May 29, 2023Follower
Second Netgear Wi-Fi Mesh Range Extender EX8000 or NETGEAR AC1900 Wi-Fi USB 3.0 Adapter
On the second floor of my home last year, I installed a Netgear Wi-Fi Mesh Range Extender EX8000, which boosted the wifi signal and network stability. The first floor is where the router and fiber mo...
May 29, 2023Guru - Experienced User
I usually don't recommend using more than 1 mesh extender as there isn't anything controlling them and they can end up connecting to each other. You can always do the same but set the 2nd one up using a different ssid. That can help combat the instability you see by using more than 1 extender.
Or you could check into upgrading to an actual mesh system like orbi. I'd look at the tri-band versions with what you're doing and the size of your home.
