pdxfunkjunkie
Dec 08, 2022Follower
Security settings for AC750 extender
Hello Community. I have a Netgear N600 Wireless Dual Band Router (WNDR3400v2) with two AC750 range extenders in different parts of the house. This setup has been working fine UNTIL we got two new iP...
Dec 08, 2022Guru - Experienced User
You can log into the router and look at its attached devices page. It should list the extenders by ip address.
Use those addresses to access them.
You can check the security there.
but you probably have them setup properly and its just apple being a pain with the notices.
michaelkenward
.. and playing around with the technologies it uses.
pdxfunkjunkie might find this enlightening:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
