KarlT0's avatar
KarlT0
Seeking cost effective options for an access point - Wifi 6, wired with cat 6
I am using a CM700 cable modem and an AX1800 Wifi 6 router (RAX10) and they are working great for me. The router is setup with ODFMA and Smart Connect since that seemed to be recommended (though sinc...
  • michaelkenward's avatar
    michaelkenward
    Jun 04, 2022
    KarlT0 wrote:
    The language out on the netz is not always so consistent.
    Oh so true.
    There are for example mesh solutions, access points, and network extenders all available, wired or not wired, and on.
    For a Mesh extender to work, it usually has to connect to a router that also does Mesh.That's because the two devices have to talk to one another in the right way. A common approach to Mesh is to buy a bundle of router and satellites (extenders in another guise). Netgear's Orbi range sets out to do that in a simplified way.
    I was surprised that Netgear says this can implement mesh with almost any router (not necessarily a "mesh" router).  I didn't take advantage of that, but that looked interesting.  And we do not need seamless roaming.
    A surprise indeed. But if you want to play around you should be able to recover some of those lost features by using the EAX20 as standard  extender, with a wifi connection to the router rather than the wired AP connection.
