dmrkvtz
Jun 20, 2022Follower
serial number EX7000
My EX7000 works fine but I can't find the serial number. It's 4 1/2 yrs old and somewhere along the way the "lable" has gone missing. How can I find it?
Thanks
1 Reply
1. what do you need the serial number for?
2. if you look at page 11 in the manual, you actually slide out the product label that has the serial number on it. Did you check that?
https://www.netgear.com/support/product/ex7000
