Samuelbrody
Sep 18, 2020Aspirant
Set up - N300 WiFi Range Extender
Hi guys, apologies if I am missing something key or obvious. First of all, I have set this up before and it worked well, however now, for some reason the Ethernet cable does not work and I cannot con...
Sep 18, 2020Guru - Experienced User
When its plugged in, what are the lights doing?
Are you able to access it when you hardwire a pc to it?
- SamuelbrodySep 18, 2020AspirantSo when it’s plugged in all the lights are on, all green, as expected if it was working!
I haven’t tried using a PC as of yet, as the only device I own is a work laptop, would you recommend that? With the Ethernet cable plugged in to my PS4, it still wasn’t working!- plemansSep 18, 2020Guru - Experienced User
It might need to be re-installed using the manual method.
It tends to go better connecting to it via ethernet for setup. Your work laptop would work fine
- SamuelbrodySep 18, 2020AspirantOK perfect I will give that a go and get back to the thread with an update.
Is there a guide on manual set up available on this website?
