Samuelbrody
Sep 18, 2020Aspirant
Set up - N300 WiFi Range Extender
Hi guys, apologies if I am missing something key or obvious. First of all, I have set this up before and it worked well, however now, for some reason the Ethernet cable does not work and I cannot con...
Sep 18, 2020Guru - Experienced User
the support site, the 2nd video walks you through it.
https://www.netgear.com/support/product/ex2700
Samuelbrody
OK so I plugged in the Ethernet cable to the extender and my laptop, I have recently moved properties so it shows up as a wired connection as (My previous internet) with EX2 on the end, and also the one I have been using for a little while at this property shows up via WIFI but provides no connection.
Therefore obviously I cannot progress and sign in on the website given to sign in (for some reason I’m not permitted to type the website out?) on the laptop as I cannot connect to any WIFI associated with the extender.
Any advice on this?
Any advice on this?
- plemansSep 18, 2020Guru - Experienced User
again, factory reset it and then reinstall it using the hardwired in device.
