KKeeton
Feb 01, 2025Initiate
Set-up AC1750 WiFi Mesh Extender, Model EX6250
I purchased a new router and cannot set up the extender. I am using the NightHawk app. I have selected my networks and entered the password. I get a message saying the password is incorrect.
- Feb 02, 2025
glad it worked! might mark it solved so others aren't still trying to fix it 🙂
Feb 02, 2025Guru - Experienced User
1. what router did you get?
2. try the installation assistant and not the app or wps.To factory reset, push and hold the reset button for 7-15 seconds while powered on. Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
