Stevenholzman
Aug 26, 2024Follower
Set Up AC750 Wifi range extender
HI I have purchased and used a AC750 WIFI range Extender in my previous home and it worked great. I now have moved house and I am trying to set this up for my new house. After I have set this up the ...
Aug 28, 2024Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
