Kelmar05's avatar
Kelmar05
Follower
Apr 18, 2019
Set up N300 Range Extender
My extender is not pairing with my router.  I push the WPS button on the extender and then on the router. It blinks but does not go to solid green. I have unplugged the router, turned it off and on and turned off and on the range extender too.
1 Reply
  • plemans's avatar
    have you tried logging into the device and doing a manual setup instead of using wps? Its a litlte more complicated but still works. Its how I prefer to do it versus wps.
    Here's the manual. Page 10 starts with the manual setup. You can hardwire into it as well for connection.
    https://www.netgear.com/support/product/EX2700.aspx
