weyzer07
Sep 30, 2012Follower
Setting up 2 WN3000RP to one router
Hello There, Here's my problem. My router is a netgear N9000, i have a large old house and the router is on the second floor. I have a WN3000RP on the first floor which works great, unfortunately i ...
dsteinschneider
Nov 13, 2012Aspirant
Why didn't anyone from Netgear answer this sure to be commonly asked question. I looked all over the documentation, online KB's and Newegg and Amazon user reviews in hopes of discovering some guidance on how to add the second WN3500RP.
The Push and Connect method worked for the first one. The second worked using the same method but the same SSID was used (why not look for existing ones and change SSID to EXT1, EXT2 etc?)
I called into support and they gave me a ticket but when I logged in it's not there.
Netgear should be doing a better job with this type of support
