weyzer07
Sep 30, 2012Follower
Setting up 2 WN3000RP to one router
Hello There, Here's my problem. My router is a netgear N9000, i have a large old house and the router is on the second floor. I have a WN3000RP on the first floor which works great, unfortunately i ...
Maxime
Nov 23, 2012Aspirant
Repeating a repeated signal is a bad idea. A repeater halves the signal each time it is used. With a cascade of repeater (one repeating the other) you end up very quiclky with a too small throughput to be of any use.
Try Powerline instead.
