soberhonu
Dec 10, 2020Initiate
Setting Up 2nd Netgear AC1200/R6220 Router as an Extender
I need help. I purchased a second router to use as a wi-fi extender. Same Netgear model AC1200 / R6220 dual band. The reason is so I can increase the signal around concrete walls. How can I do th...
- Dec 10, 2020
the r6220 doesn't support extender/repeater mode.
If you can find a way to hardwire it in (powerline, ethernet, moca adapter), then you could run it in access point mode.
Dec 10, 2020Guru - Experienced User
- soberhonuDec 12, 2020Initiate
My best option from your reply is to ethernet hardwire. Guess I just run from my modem to the 2nd router and use it as a 2nd access point? Sounds simple. Thank you very much for the reply
- plemansDec 12, 2020Guru - Experienced User
yes you can just use it as an access point
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode-after-setting-it-up
