soberhonu's avatar
soberhonu
Initiate
Dec 10, 2020
Setting Up 2nd Netgear AC1200/R6220 Router as an Extender
I need help.  I purchased a second router to use as a wi-fi extender.  Same Netgear model AC1200 / R6220 dual band.  The reason is so I can increase the signal around concrete walls.  How can I do th...
  • plemans's avatar
    Dec 10, 2020
    the r6220 doesn't support extender/repeater mode.
    If you can find a way to hardwire it in (powerline, ethernet, moca adapter), then you could run it in access point mode.
