TBeanMarie
May 28, 2020Follower
Setting Up Extender on Another Network
Hello,
My wifi extender is currently connected or paired to my home router/network. I'll be going on a camping trip and using the RV resort's wifi. Can I connect my extender to the resort's wifi like I did at home? I mainly need to use the ethernet port on the extender for an IP phone so I can continue to telework while I'm at the RV resort. The phone has be be connected directly to a router in order to work. I appreciate any feedback! Thank you.
1 Reply
Thats tough to tell you.
Some places, maybe. Some not at all.
Reason why is different RV parks use different wireless and security features. Some you simply connect to and they don't require login's or anything like that. Others do. If they have specific login's/security settings, then many times you need something like a travel router and not an extender.
